Beosound 5 settings
Hi, Have problems with Beosound 5 setting. I can just have the normal ones like sound but if I want to go further......no. Other thing is that I can't see configuration menu from BV9. TV detects Beomaster and I can adjust volume but that's all. ?? Also could not download Beoconnect program to MacBook. "untrusted"
Hi, Im a bit rusty on BS5 settings with ML TVs. Hopefully this will give you pointers to self-diagnose.
  1. BeoSound 5 / Beomaster 5 Connection Audio BeoSound 5 can be placed in a setup, where either BS9000, BC2, BC2AO, BS3200 or BS4 is used as audiomaster and BeoSound 5 is used for N.MUSIC and N.RADIO.   Audiomaster YES/NO on BeoSound 5 must be set to NO in this setup. This will disable OPTIONS setting for the BeoSound 5. The OPTION setting, referred to in this conclusion refers to the Audiomaster.   Selecting option on the audio master Option:  AUTO configurating (option 0) ********************* AUDIO/VIDEO/LINK SYSTEM SETUP ******************* Connection Connect the Master Link socket of the audiomaster to the MASTER LINK socket of the TV-set using a BeoLink cable. ********************* REMOTE CONTROL FOR MAIN ROOM ******************** The recommended remote control is Beo4 The following remote controls may also be used: Beo5 Setup for Beo4 remote control: Beo4's "LIST" must contain the following items in order to be able to operate the Main Room products.
  2. You will not see the BS5 on the TV. However, you will get Beomaster5 contents on N.Music or N.Radio
  3. Connect Beolabs to the TV PL outputs and not the BS5
Ok............but how about those system settings? How to go there? I can just setup volume, balance etc . On system settings I just get "language"and "time zone" There should be some way.
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SOUND_SYSTEMS/BEOSOUND_5/beosound5_userguide_english.pdf
Well.........not working. No service settings available. Seems also that volume etc. settings not there. If I shut down the whole thing and take the mains totally off for awhile and restart then settings are available except those service settings.......:/
