Beoplay M5 as a hub
Dear Forum,
is it possible to Connect a Beolab 7 speaker to a Beoplay M5 via minijack and use the Beoplay speaker as a hub/bridge for the Beolab speaker in terms of Streaming Music?
Thanks in advance
Boj
No!
Thanks Millemis for a direct answer.
... but both the Essence (pref Mk2) and NL/ML Converter have powerlink outputs and either could act as a 'hub', depending on what you are hoping to achieve.
… And the Playmaker if you want to stream from a computer.
