Beoplay M5 - No serial number
Hi. I just bought a used Beoplay M5 and made a factory reset to add it to my network and the B&O app.   Now the problem. The B&O app are not seeing the M5 at all. I've tried to reset several times. I finally got it onto the network through airplay setup, but the app is still not finding it.   So i downloaded the app "BeoTool" and noticed that the serial no., item no. and type no. is: "0000000" so I guess that's why the B&O app wont find it. When connecting to the M5 through ip-address and looking at the "critical logfile" it comes up with: "unable to initialize core client: one or more of the arguments are invalid."   I can still play music via spotify connect, and bluetooth is working but can't software update it. Am I totally doomed or can it be corrected by any ways? There is a label inside the M5 with the serial number.
I haven’t heard about this before - but it seems to be a fake M5, a copy. Have you contacted the seller about this? Could you post some pictures? MM
seller told it was legal.. everyone can say that of course. sure, here are some. software has been updated previously, so the data must have been there before.
So. I wrote to B&O support, and they sent my a guide with a special software to recover the missing data.   Connecting to the product through webbrower, and uploading the software did the trick :) Now the B&O app finds the product. Don't know if this is a common error, as the headline of the document says "How to recover ASE-TK product with serial number 00000000 (BeoSound 1/2, BeoPlay M5)"
Great - we should be happy to be the costumers of such a company. Not many would offer that kind of service for a buyer of a second hand product, that is long eol. Personally I haven’t heard of this before - but obviously they knew. Have fun with your M5. P.S. This should be the latest/recent sw: Software 2.1.50868 - Release date 31st October 2022 MM
Hi Guys,   I have the same issue with the M5. Who can i contact for the firmware to fix it? @HerlufHansen is it possible you can give me that special firware?   Thank you
Hi there. Sure I can. Will find it later when I get off of work. :)
HerlufHansen wrote: Hi there. Sure I can. Will find it later when I get off of work. ?
Really appreciate it! Thank you
Hi ! I'm also facing such a problem, I'm glad I did a search to find this form and discussion, is that possible to have a copy of the software that can help me get it recovered? Cheers mate!
Hi guys. Sorry I didn't write yesterday - Was a bit busy. I've added the guide I've received from B&O support. There is a direct download link from B&O to the SW inside the PDF Hope it works for you guys too :)
