beoplay connection hub & beolink passive
Hello all,
I was planning to use a Connection Hub, and a Passive to drive 2 BeoVox speakers from a Samsung TV, controlled by the Samsung remote. At my parents in law, for ultimate remote control ease and good sound.
I sourced the Hub, tested it with the optical out of my Mac, a PowerLink speaker, a PowerLink Mk 2 fully wired cable and an (LG) IR remote. It works just fine.
Now I just received the Passive and am testing it, but it does not switch on when the Hub switches on. Now I have two thoughts:
1. Could the Passive be in the wrong option?
2. Do I need to fabricate a cable that connects pin 1 'Power on' and pin 4 'speaker on/off'?
Maybe someone has been here before and can let me know, also if there is something I am overlooking.
Thanks! Regards, Johan
Could you elaborate on the 'Connection Hub'?  I assume that it is simply a digital (optical) to analogue converter? But is it something more complex with a PL output?
Not if it is being used as a stand-alone amplifier (without ML input and IR eye)
2. Do I need to fabricate a cable that connects pin 1 ‘Power on’ and pin 4 ‘speaker on/off’?
I think that the Passive trigger needs to be 5v to Powerlink input pin 4 (pin 2 as gnd). Perhaps the TV has a USB socket that you can use to supply this? EDIT:  But this thread suggests that both pin 1 and pin 4 need to be triggered: /forum/general-discussion-and-questions/beolink-passive
I now believe the trick could be in the signal the Hub provides. I reckon it puts 5V on pin 4 (for regular BeoLabs to switch on), but the Passive expects a signal on pin 1: (snip of the service manual)
I agree - see my edit above linking to this thread: /forum/general-discussion-and-questions/beolink-passive (Hence the need for fully wired PL cable in some setups, so that both pin1 and 4 are connected from B&O PL source to Passive)
Hello Guy, thanks for thinking with me. The hub I refer to is the is the BeoPlay (S8) connection hub:
Good to hear you trust it is not in the option setting.
Now I hope that the Passive expects the same 5V voltage for pin 1, so I can make a specific lead (RJ45 to 8pin Din) What do you think?
Regards, Johan
Great stuff Guy. I will see to fabricate a cable and report back.
Many thanks! Regards, Johan
I got it working. The only thing to do (at least for a Passive 1656) is to get the trigger signal from the 'speaker on/off' (DIN pin 4) onto the 'power on' (DIN pin 1).
In the end I decided not to cut/solder funny cables, you never know when you will fool yourself with it later :-), so just wired a two port RJ45 terminal this way:
All that is needed are those 5 connections. I = in, O = out.
I run a Cat7 patch cable from the Connection Hub to the terminal in (I), and a PowerLink Mk2 RJ45 to 8 pin DIN cable from the terminal out (O) to the PowerLink socket of the Passive. PowerLink Mk2 is needed as it has the 'Power On' wire going to pin 1.
Hope it is useful to someone sometime.
Thanks Guy for your interest and support.
Regards, Johan
Thanks for the update and great news that you got it all working - I am sure that this will be useful to others.  I am a big fan of the often-overlooked Passive.
Just for completeness, you referred to B&O's Powerlink Mk2 RJ45 to 8-pin DIN cable so I thought I would post a pinout diagram of this cable here so that others can see exactly what is going on with the grey 'power on/up' wire:
Same logic, but with a little more elegant box (to put into the TV cabinet of my parents in law):
^ Very neat - what make/model is the little 2 port terminal box?
Thanks Guy! This should help anyone replicating the solution.
Some commercially available RJ45 to 8pin DIN cables seem to differ a bit nowadays from the table on the right.
The 'Data GND' is a separate copper strand in the cable (not a shield around the white 'Data' wire).
The 'Signal GND' wires are not braided copper shields but green (R) and brown (L) isolated wires, marked with a thin white stripe, per pair isolated with aluminium foil. The total bundle of wires is shielded with a braided shield. See below pictures:
