Beoplay A9 keeps diconnecting
Hey everyone! Happy New Year! For a few weeks now, my Beoplay A9 (MkII) keeps disconnecting daily. The A9 appears as unreachable in the B&O app, and I have to take the plug out and force a restart in order for it to show up again. Sometmes this even happens while playing music, in which case the speaker is again unresponsive and I cannot turn it off even from the touch controls (I still have to plug it out). I tried Googling about this issue and searching the forums but nothing came up. I believe that a new firmware was released recently and I thought that perhpas this might be causing the issue? Has anyone experienced something similar? It is definitely not a WiFi issue, as the reception is quite good and stable (I have a 200Mbps FTTH connection, and everthing else works fine) and I don't experience the same issue with a BS Stage nor a BeoSound 2 that are located further away from the router. I have also tried both the 5Ghz connection (which I normally use) and the 2.4Ghz, but the issue persisted regardless... Any ideas on what might be causing this and/or what I could try to fix this issue? Many thanks in advance! Harry edit: just saw that the post count was reset in the new forum. I'm an old member so I hope it's ok if I post a new topic...
Same problem here.Anyone got any solution to this problem as this is very frustrating.
I ended up selling the speaker and getting a Mk5 a few months ago. It was just too much of an incovenience to keep having to hard reset the A9 almost daily.
