Beoplay A3 App
I require the iPad 2 app; can anyone kindly do me a favour and send me the app, please?
On iPad, it is impossible for anyone to send you the app.  The app may only be downloaded from the App Store, if it is at all available.
I am rather curious as to whether you eventually solved this issue.  Can you share?
The B&O setup iPad App is useless: it don't add no or out any feature at all.
The only thing that happens when you dock an iPad to the A3 is a specific speaker adjustment for voice or music that appears in the settings section.
This appears whether the app is installed or not.
