Sound control from LG TV to Beomaster 6500 not possible
Am I the only one having this problem? My old LG TV had a headset jack output, which I used for input in my Beomaster 6500 and Beolab 8000. It has worked fine for many years. I really only use the BM6500 for ChromeCast Audio and TV sound to my Beolab 8000 speakers.  So it not a must to me keeping the BM6500 :-) Now I have bought a new LG TV, where there is only HDMI eARC and Toslink output. I have tried a several digital to  analog adapters (HDMI/Phono, Toslink/Phone). Best case sound comes through, but I cannot control the sound from the TV as I could on the old TV. Is there a way to control sound from TV or is trying to control the sound from the TV a hopeless project? I know of the B&O Core, but I am not sure if that does the trick.
Hi and welcome to Beoworld! I think that you will need to use an hdmi extractor that also incorporates CEC volume control (so that the TV's volume control can control the device's analogue audio output volume) .  I found something on AV Forums that points to a device called the SHARC eARC audio converter.  It is described here but listed as discontinued:  The description states: Supports CEC switching and command passthrough using the TV remote and the source remotes.
  • Use AppleTV / Roku / Xbox / other remote controllers to control the volume level, mute and source switching.
  • Volume control applies to the audio system connected to the HDMI output, line-level RCA outputs, and the headphones output.
Thanks Guy I ordered the shARC v2 today. You are right - it looks very much the one I need :-)
Great - come back and let us know how you get on with it, as I am sure that others will have a similar requirement one day!
I received the  shARC V2 and set it up. It worked, but I  was not satisfied because it reacted very slow, and sometimes not to the  LG Magic Remote sound control . I wrote with ThenAudio support and they sent me a new Firmware, whihc I installed on the  shARC V2. This solved my problem to my satisfaction. Thanks to the nice guys at Then Audio, and you Guy :-)
Great news - I'm very glad that it worked and many thanks for letting us know.
