need your advice with beomaster 4000 repair
Hi, I need some advice regarding repair of a Beomaster 4000 (2406). It came to me as a botched repair with right channel darlingnon transistors burned out (TR43/46/47). TR44/45/41/42 were also burned out. I replaced many out of spec resistors and all electrolytic capacitors. I started testing with output darlingtons disconnected to ensure all voltages are correct. The left channel would balance out with correct voltages, but the right channel would not - the TR43 would stay on VCC (70V), instead of about half that value. I noticed that the replacement TR44 (BC114) does not conduct during the power up sequence - the Vbe is about 0.3V at all times. TR41/42 never get to conduct, which in turn never sets correct base voltage for TR43. I then swapped TR44/45 pair with TR55/56 (left channel) to ensure that the replaced components and board work in the right channel is correct.  Sure enough - the voltages on the right channel are now measuring correct, but the left channel now has the same problem. This lead me to a conclusion that the difference is in BC114 and BC252B pair between two sides. Using a transistor tester I tested all four transistors. The BC114 on the side that works tests with a very low Vbe forward voltage (0.2V) compared to the replacement BC114 I purchased (0.66V). This does not make sense since the BC114 specification sheet shows Vbe of 0.64-7.0V for both. My question for you is: is there anything special about BC114 transistor used in Beomaster 4000? I see that service manual shows two revisions of the bias circuit for these two transistors. Is it worth implementing these revisions to fix this problem? I must say I am a bit perplexed by the complexity Beomaster 4000 feedback loop and the fact that BC114 the working channel does not measure as specified. Thank you for your help. Vlad
Attachments (1)
Can someone with Beomaster 4000 (2406) help me get some traction on this problem?
