Help with rebuild of Beomaster 4400
Hello Everyone,
I am in the middle of renovating my father-in-laws Beomaster 4400 type 2417 for my Wife as a memory of her dad, who passed away.
When I dismantled the unit I noticed a disconnected blue wire that joins the left switch pcb to the right pcb but cannot work out which point it should be soldered to. The only pictures I have been able to find are of the model 2419 and the wire connection patterns are different.
I have attached some pictures in the hope that someone can assist.
Thanks,
Brian
You can see it here:
https://beolover.blogspot.com/2020/03/beomaster-4400-type-2419-investigating.html
Half way down the page.
Hello Dillen,
I got everything back together and then when I powered up (via isolated variac and dim bulb tester) the unit did not power on at all. I removed the base cover and tested the voltage across the power switch, there was full voltage supply (blue/brown wires in pic below) but zero voltage on the white/grey & brown when the switch is in the on position. It did power before the refurb and the switch has not been touched during the refurb. I notice that the wiring on this 4400 type 2417 is very different from the type 2419. Any ideas about what may have gone wrong or has the switch just failed?
Thanks,
Brian
These switches are notorious for failure due to arcing damage…..it’s quite possible the reason for your issue, very difficult to repair/replace too ?
Yep, I tried to find a replacement but without luck. Probably try in vein to ask B&O direct then try dismantle and remanufacture.
If anyone knows of any leads to a possible supplier I would be grateful.
Best Regards,
Brian
Here is what it looks like. I installed a micro switch 220v 10 amp on the steel plate below the switch actuated by the plunger that actuated the original switch, sorry no pics of that Login to view image
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
