Connecting to BM5 with a Mac
Hello guys. Need your help with Beomaster 5.
I have a BM5 and I'm trying to connect to it via an ethernet cable. I found the IP of the system and I use CMD+K to connect to a server. However, when prompted for a user name and password I enter BM-USER (as stated in the network settings of the BM5) and a client password that I set (A in my case).
For one reason or the other it doesn't recognise the credentials and I'm stuck at "user name/password screen". I tried changing the password, rebooting, changing client name and password, rebooting, but to no avail.
Anyone had similar issues? I attached system info file just in case.
As I have the exact same setup, if you are there, we can try a few things. Let me know.
Let me know what works :) I'm happy to check it out
With regard to your product info screen cap, we have the exact same, with the following exceptions:
- My BS5/BM5 Application is 7.04.01.1945. Since everything else is pretty much the same, I wonder if you haven't updated to the latest version. I let mine update itself a couple of months ago and has worked fine since (it also worked fine before). Others on this forum have confirmed that this version is the latest —and last, in all probability.
- My BM5 OS Update is 7.03. Comment is the same above.
- My BS5 BOM is 5, yours is 3. I have no idea what this is, but I speculate this characteristic is immutable from the time the device was built.
- My serial numbers are a bit higher than yours, but that's probably very irrelevant.
