Connecting Beomaster 5500 with Beolab 6002s
Hi all, I recently got ahold of some BeoLab 6002 speakers to hook up to my Beomaster 5500 (1989/1990 model). I’m running the Powerlink cables from one speaker through the other, so I only have one 7-pin DIN connector to the Beomaster. From what I’ve understood so far, I need a DIN-to-Phono adapter, and then to connect the two Phono jacks to the ‘Pre-Amp’ output on the Beomaster. Can anyone confirm if this is the correct way? I’m still a novice, and really want to avoid blowing out my speakers!
I would speak to Steve at Sounds Heavenly; he is very helpful regarding all sorts of connection cables.   He can be contacted on this site or on the Sounds Heavenly website where cables for a variety of brands, including B&O, are available. I can see your reasoning for a DIN to Phono adapter cable (as I have a 5500, but Beolab Pentas) - that type of cable is available from Steve.  He may be able to advise a better method though, so it would be worth messaging him.
