Connect with Mac to BeoMaster 5
Hi, I have done this many times.... but not recently. Can anyone remind me how to connect a Mac to BeoMaster 5 to access the media files? I used the command smb://ip address of the BM5/bm-share$; then entered the username BM-USER and my password. Unfortunately, it doesn't work. Update: I could make it work by re-entering the password in BeoSound5. A bit weird. Guy
On Finder: ⌘-K or Finder > Go > Connect to server... You should get a dialog: Enter your password.  Mine is very, very long and of course unique to this device. If you enter the correct password, a folder will open up:
Thanks!I actually solved the issue by re-entering the password in BS5. Must have gotten lost since I last connected quite some time ago.
