Beomaster5 problem. Help!!!
I bought a used Beosound5 with a Beomaster5. But strangely, when I turn on the Beomaster, only the power-on light at the top of the screen comes on, and the Beomaster5 also turns on but does not work. So I copied the hard disk through cloning and reconnected it, but the Beomaster5 still does not work at all. I removed the cover and looked inside, and only three lights are on, and the light on the left should be on, but it is not on. Is this a problem with the main board? Or is it possible to repair it? Please give me a solution. Please.
Hello,
You seem to be missing 3.3V ATX.
These devices are complicated to work on, so I would suggest returning the system to your local service centre.
The service documentation is not publicly available at the moment for this product.
Kind regards,
Pete
Peter Fraser
Service Technician
Multicare Electronics
