Beomaster 7000 2-way does not work
After recapping my Beomaster 7000 the 2-way communication does not work. I originally did the recapping because the amplifier was getting a bit hot even though the idle current was set at 11 mV. The good news is that the Beomaster is almost completely cold now. The bad news is that my beloved 2-way function is not working. Any idea what could be wrong or where to look. I have the service manual but not completely sure what to look for.
Have you checked the lithium cell 3V and the option programming?
The display is ok?
The ir sender use a pretty high voltage... 32V when i remember right... and the axial caps are pretty old. I found already some of them with a short, and a burnt resistor on the display.
But it can also be dirt on the red plexy glas.
I replaced the 3V battery - didn't actually need to as it measured 3.1V after all these years still.
Yes, I checked the option.
The display is okay.
I replaced on the front panel these capacitors - they all had very high ESR measurements
C15 1uf/100V ESR 40.3 BAD
C19 2.2uf/63V ESR 14.2 BAD
C20 10uf/63V ESR 2.30 BAD
After this, I checked that the amp was working but I did not check 2-way communication.
I also replaced 2 capacitors on the CPU board - both of them gave no ESR whatsoever:
C1 100 uf/10V - measured capacitance 14.7 - way out of spec
C57 47uf/10V - measured capacitance 11.7 - way out of spec
So, I presume that I may have done something wrong with one of these capacitors - or they need to be a certain brand. The two from the CPU board were the blue Philips type as well as two from the front panel.
What remote are you using, and have you checked its two-way functionality with another Beomaster?
I have a Beolink 7000 and Beolink 5000. Both of them worked before I recapped the Beomaster. Highly unlikely that both of them would fail at the same time - especially since I repaired their 2-way communication module 1-2  years ago.
Hmm - I have a hard time trusting my ESR metre. On the front panel board, I get open line readings on these:
C3, C5, C7, C8, C9, C11, C12, C16, C18, C23, C24
However, testing with the multimeter, only these ceramics give me no reading/reaction:
C5, C11, C23, C24. Still it's a lot of ceramics ...
Putting power on the board, only C5 is suspicious with a voltage across it of 0.142 V DC
Hm. I have about 28V on the diodes
Have a look at the connectors...
To check that the TX IR LED is active (transmitting) you can use the front camera on a iPhone or iPad.
/steffen
