I have a BeoMaster 7000 that has had recapping in the power supply and IR/CPU board and the voltage changed to 240V.
Previously I haven't give it much thought but upon measuring I found that the BeoMaster 7000 measures 40° celcius at the heat fins on the back of the amplifier. Granted it is warmer today at measurement.
Still, what is correct temp within specification? I suppose it also depends on the environment so asked in a different way how much warmer should the BeoMaster be than surrounding temperature?
