Beomaster 6000 4channel Lamp Replacement
Hey everyone! I’m working on cleaning up a beomaster 6000 4channel and if got everything working but I can’t seem to figure out how to change the bulbs. I know I have to solder them in there but I can’t seem to figure out how to get to them. This is where I’m at currently and I got a bulb kit from danish sound parts. Please help!
Hi
Are you changing out all the lamps on the machine or just those that have failed? Some lamps are fitted into an enclosed plastic compartment, others are not. You will need to open the unit up to access all lamps…..check out the service manual available here for a better idea, be sure to replace the lamps according to the description provided by the supplier, the current ratings differ from location to location…….enjoy 👍
Ok
you will need to lift the indicator ribbon display section up into the vertical position to access the lamps….2 screws as I recall, these lamps are connected in three series loops I think…so if one goes down you loose 2 or 3 lamps….its been a couple of years since I changed any. As a silver member you can access the service manual for this machine under products in here, this details how to open it up…..unfortunately im windsurfing off the coast of Greece until Sunday….if no one chips in with more help I will open a machine up and send some pictures to guide you next Monday when I return to the UK
Craig
Craig
Ah wonderful thank you so much! Wasn’t sure if I’d need to lift that up or not. I had only found the manual that shows what all the things on the boards were and it scared me off so I’ll have to keep looking haha have fun windsurfing! How fun!
Just had a look in the manual myself and your correct it doesn’t detail the disassembly, I thought it did…..not to worry, is the amplifier fully functional right now apart from the lamps? It’s good to know that anything that stops working after you do anything in there is a result of what you have done which often makes it easier to correct 👍
Yeah it’s working great other than the lamps! I had gone in and fixed a few other things so this is the last thing I need to do and it’s working great as of now so I’ll know if it messes up anything haha
Excellent…..these amplifiers are getting rather rare these days and need to be looked after, amazing pieces of engineering…..
craig
craig
Ok.....so you have got this far
The lamp holders are located as shown here....
