If I select CD, TAPE or phono it will flicker between sources in the display and a relay is clicking continuesly.
If I select radio this doesn't happen
The last thing it was used for was in a test scenario with a Beolink converter connected to the TAPE2/AUX input if this can give any hint as to what could be the reason for this behaviour.
Any ideas where to start looking?
Thanks in advance
