I have seen some other posts about this problem but i could not actually identify the parts that those solutions referenced... something about the idle current trimmers?
the issue is that the amp cuts out and goes back to idle every 20 seconds. (red dot on screen showing it has power) this is weather it is playing music or not, with everything plugged in or nothing plugged in, it doesn't make a difference.
I have basic/no electronics knowledge, i can do basic soldering but not much more.
I have opened up the amp, dusted, used an airbrush to blow out all the dust. i cant see any obvious broken connections etc.
The only thing that is broken on it is the front panel does not actually shut properly, although i doubt that would link to this issue?
Thanks for any recommendations you have.
