Beomaster 5000
Picked this up a couple of weeks ago......should have more sense after all this time!
Its in a bit of a state.....looks like its been through the wars
Sold as fully functional.......however I think a bit of cleaning (quite a bit actually) and replacing of dried out capacitors will be required before power is connected, some replacement veneer too I'm thinking
Making a start on "the low hanging fruit", to quote a project manager I once worked with. A friend of mine spent some time cleaning up the curser.  Interestingly this piece isn't anodised like the face plate, which is probably why it oxidised so badly, I'm told that one can determine if something has been anodised by the use of a multimeter set to ohms......if something is anodised it wont conduct?....I will test this. New felt pads will be included too.
this is the internals.....was sold as "restored by seller"..............
P1016773
made a start on the cabinet top, was in a bit of a mess so re shaped the smashed corners ready for veneering.....
I've decided on this african iroko veneer.....will need to stain it in order to darken it down to match the Beogram 5000 it will be paired with
This is a slow and painstaking exercise requiring a lot of sanding and swearing.......cant hurry the glue drying process either....
Oh.....and this has arrived from Frede......such excellent work, was a little miffed at having to pay import duty on it now that we are free from the EU ;¬)
Cabinet top veneer finished, shame to stain it actually....I quite like the iroko wood grain, but will have to match the Beolab or it will look odd.
