BeoMaster 5 and A.AUX
Hi all, my good old BS3000 stopped working this morning. I have contemplated buying an SSD upgraded BM 5 for a while and am ready to do now. I believe I understood how to add music to the BM 5 thanks to this forum. I have two questions though:
  1. I still have an old BeoGram and TapeDeck that I would like to connect to the BM 5. How does that work. The manual is kinda fluffy about the USB Adapter needed. Anyone out there can shed some light on this?
  2. Most BM 5s seem to come w/o the ripping device. Would it be possible to hook up any ordinary USB CD drive to the BM 5 and it works? Or does it have to be B&Os ripping device?
Thanks for your answers cheers Torsten
Right! However, the easiest way would be to use one of these: Please notice that Steve is only shipping to the UK for time being - but the Behringer can be bought elsewhere….just do a search for it. And…..if you want to connect more than one device, you’d need some kind of switch too. As for the 2nd question - I remember back in the days, that I had a stock external USB drive connected….so yes that should work! I would however, not recommend it - it will be much easier to use a PC/Mac for this, because you will have to tag the files properly in order to have these searchable and showing coverpics etc on the BS5. MM
The setup would look something like this: BM5 -ML- 1611 -7 pin Datalink- MCL2AV – Beogram/Beocord
Yeah, I've been following this thread with a mixture of amusement, fascination and sheer respect for the amount of knowledge present in this community. I have started to put out searches in ebay classifieds to see whether I can source the components at reasonable prices to also build such a setup.
Thanks for both hints. Found my old USB CD drive and hooked to the Mac. Still works :-) So that should be easier. Agreed.
Yeah, I’ve been following this thread with a mixture of amusement, fascination and sheer respect for the amount of knowledge present in this community. I have started to put out searches in ebay classifieds to see whether I can source the components at reasonable prices to also build such a setup. great to hear that orhers are also following our little black box adventure ? let us know if you needany input. one buying advice for the MCL2AV is try to get one with the original power supply to be sure it has the right polarity on the power connector
Good morning together, my BeoMaster5 has not been in standby mode for quite some time. The BM5 is linked to BS5 and BL 8000. What strikes also the tracer is not functioned for switching off and turning on at the back any more. Is this a software or hardware issue that the board is defective. Also have already tested different options via the F8 key with connected keyboard at restart, but came to no result. Does anyone have any advice on what it might be? Thank you in advance greeting Andreas
