Beomaster 5 - RCA input
Does anybody know if it is possible to connect a DAC to the RCA connections (R/L) on the Beomaster 5 to basically get sound from any device? If so, how does one setup the Beomaster?
Hi KarstenS, the RCA connections are outputs. Check this https://soundsheavenly.com/music-input/17-beomaster-5-beosound-5-aux-usb-input-converter-also-works-as-pcmac-sound-card.html to use a USB port.
Regards, Johan
