I recently acquired a Beomaster 4500. When listening in FM mode the unit work perfectly. I got a 5DIN to 3.5m cable to connect my AirPort Express and be able to airplay music wirelessly from my phone. When I do so, I only get audio on the right channel, regardless of which speaker bank I plug in the speakers too. When I switch to FM mode, stereo works just fine. I have moved the 5DIN cable to all sources (AUX/CD/TP1/TP2) and same result. I also tried a 7DIN to 3.5m cable and same results. The seller said the unit worked normally in stereo mode when used with a BeogramCD player. Any advice on what could be my issue and how to properly play music wirelessly via AirPlay in stereo mode? Thank you all for the help,
-Veso
