Beomaster 4400, bump on the speakears
Hi to all, I'm an old enthusiast of B&O products. My collection began over 50 years ago with a wonderful Beomaster 5000. Then came the Beomaster 1400, 3000, 1900, 3300, Beossound 3000 mk2 and now the Beomaster 4400. I just bought this last one and it works very well but I have a doubt. When I turn it on there is a bump noise on the speakers. I ask you if it is normal because I saw from the wiring diagram that there is a relay but I think it is connected to the protection device and not instead to a delay in connecting the speakers to avoid this. Someone can please clarify this. Thank you.
The bump is normal. The relay is on the PSU rails, not the speakers.
Jacques
  1. Ok, thank you. I found a stupid but easy way to avoid the bump.  Just turn on the beomaster with the speakers unplugged :-). B regards
Or use the speaker switch, perhaps. ?
Jacques
lollo:  You might want to put a multimeter across the speaker outputs and check the DC offset voltage. This should be very close to 0.0V. Sometimes power-on "thumps" are normal/unavoidable, other times they are indicative of something else. It is hard to judge what you are actually experiencing from the information that you provided.
Glitch
  • Ok, thank you. I will measure with the multimeter if there is Dc voltage on the speakers after switching on the beomaster.  If so, it would be a regulation problem of the final stage of the amplification which should thus be verified and investigated. But probably the bump is normal as Chartz reported. Yes Chartz, I use the switch to disconnect the speakers :-).
My assumption was that you were experiencing something different than with your other/previous B&O receivers, otherwise you wouldn't have asked the question.  If there is an issue, there are multiple things that can cause a speaker thump.
Glitch
Don’t worry, the 4400 has it with 0 mV offset. Not a problem really. I’ve been hearing that thump every single day for 10 years now, ever since I restored it!
My 1967 Beolab 5000 has it too.
As an aside, the 4400 sounds extremely good, probably my best B&O receiver.
Jacques
