Sometimes when I turn the unit on, it powers up with the volume on max. The problem seems to be intermittent. Also I notice the preset volume control doesn't seem to be working. When the unit is not turning on with volume on full, I don't notice any difference between low, med, and high.
The unit was recapped a couple of years ago and has worked fine until it was put into storage. Now it has developed this new problem.
The volume control works otherwise and is stepping up and down properly.
The preset function is pretty simple as it just pre-programs the counter.
Any thoughts?
