Beomaster 1900 TYPE 2903 - T1
SN: <1400000
Hoping someone could help trying to source a replacement relay for designator RL1. When re-assembling after re-capping I clumsily got a blob of solder to short between 2 contacts on the relay & it's damaged the relay (too much current looks to have melted the plastic pivot point which holds the reed for the relay). Not sure what other damage has been done yet, but it blew both F1 & F2, so hopefully not too much damage.
Looks like a "PASI BV 686 7076" - can't find a direct replacement anywhere.
In the service manual info on part: RL1 7600032 14,5V
Login to view image
Login to view image
Login to view image
