Beomaster 1200 FM, MW, LW lamps not working
Hi there, I was wondering if someone could literally shed some light on a problem I have. Neither the FM, MW or LW lamps are working on my system. The ON and Stereo lamps work, and I have swapped to bulbs round to eliminate the bulbs being at fault. Not sure if it makes a difference but I am testing it with the button and slider panels off.   Thanks Matt
The band lamps intensity depends on the signal strength. You could have a bad antenna signal. Martin
ah ha ok, hmm, i might have a problem somewhere. I have plugged in the antenna, albeit the white plastic connector, but none of the lamps even shine a small amount even after moving the tuner all the way from left to right
