What do I need to play audio out of my Beocenter 2 into my Beovision 11-46
I’ve managed to source a replacement socket box cable for my Beocenter 2, which should arrive in the coming weeks. I’d love to integrate it with my Beovision 11 as a CD and radio source — since I’m already using the built-in TV speakers, a pair of Beolab 3s on floor stands, and a Beolab 2 sub, I think it could make for a really nice CD/AV/Hi-Fi setup.
What’s the best way to get this working? I know the Beovision 11 no longer has ML/MCL or the older style Powerlink connectors, so I’m wondering — do I need one of the brushed silver Bang & Olufsen <b>BeoLink NL/ML Converter</b> boxes for this?
Just want to make sure I get the right setup before buying anything?
Best regards   Ryan
The NL/ML converter will probably get you the best user experience. you can connect the BC2 to the BV11 in other ways, but the control will get more complicated
I agree with Mads. However, if you just want to test it, both the BC2 socket unit and the BV11 have SP/DIF input and output. You can start playback on the BC2, then configure and select the corresponding input on the BV11. You can listen using P.MUTE. It should work — though it’s not the most elegant solution.
