- Beosound 9000 as A.Master, in A Opt. 0
- Beosystem 3 as V.Master, in V Opt. 2
- Beosound 5 set to slave mode
it gives only ever have one audio system. There are no examples where another Beosound is used in a different room, but within the same ML network.That is because of the general Masterlink linmitation that only allows for one Audiomaster and one Videomaster in the same Masterlink network. B&O only shows examples that not require workarounds in the Handbooks to ensure a smooth experience. For some audiosystems there are software updates that allows them to work as link rooms (option 5 or 6). In your case however that does not help much as you wan't the speakers connected to the BS3. However if one of your audio systems support the link room mode you could use that in option 5, as the main" audio system and get the sources from the other system (that would have to be in option 0) by pressing Link+command. You would still have the issue with the speakers connected to the BS3, but that could be solved with a Powerlink switch*, as mentioned in one of your other posts, to share the front speakers between the BS3 and the Audio system. The BS3 would have to be in option 1 then to only receive video commands. *Those are available from both Oneremote and Almando and maybe others too. A little unsure about when option 4 is availble or not in a system, but you would still have an issue getting the sound into the Main system via. AUX with an other command, so a little fidely to start something.
I have been thinking again about your setup @carolpa, and sorry for all of these questions, but if I get more than one Beolink Converter NL/ML, how exactly does that work? How do you control the devices in each room - via the device, or via the BLC (with an IR eye perhaps)? Does this work with your speakers connected to the ML device, or do the speakers need to be connected to the BLC directly? How are your BLCs set up - are they set as source centres? Do you need to use IR mapping options? Can you play the source from one room in another room? If so, are there any limitations to that? If I have my Beosystem 3 as a video source in Opt.2 and my Beosound 9000 as an audio source in Opt.0 (in the same room), could they both be connected to the same BLC? I do have one BLC NL/ML which I bought to connect my Beosound Moment into my network, but it never really worked the way I wanted it to, and anyway I prefer my Beosound 5 over the Beosound Moment, so neither the Moment or the BLC are in use right now.My set-up explained: The system is a mix of ASE and Mozart products. I should also mention that I do have BLI installed, but if you have ASE products you do not need BLI. For the moment I have 4 BLC (Beolink converter NL/ML) connected to the NL system (Beosystem 7000, BS9000, BS3000, Beocenter 2). Each BLC has only one ML product connected. The BLC is set as VMaster (or ASlave) and none have speakers connected. The BLC are Beolink connected to ASE devices as primary or secundary products and the ML sources are set as sources of that NL device (BS35, BS Core, BS Essense mkII). All the sources are now avilable on NL. I can start a source with the B&o app and/or my Beoremote Halo's and Join others (Note: the device with the source connected can be muted). Additional with BLI...... I can start any source in the system on any device in the system with my Beoremote Halo's. This is made possible by "Lua" programming of the Halo. The main difference: my system is general setup as NL with ML product added as sources.
