Problem with NL/ML converter
I have a BS3000 connected to the NL/ML converter using Masterlink. The converter is then connected to my BS Core using Network Link.
The last time I used it (admitted: it's been a couple of months), it was setup that I could select the converter in the B&O app on my iPhone as one of the sources of the BS Core. I could then use the BS3000 CD player from the Core.
However, the converter is not available anymore in the sources list on the B&O app. I can select it in the configuration screen in the app as a 'local source', but it doesn't show up in the sources list when using the Core.
I can connect to the converter from my Mac, though. I can configure it etc., so it's obviously connected to the network.
Does anyone have any clues? Has the app changed, so that I need to rearrange things?
Thank you so much.
Oh, and to add to this.
If I choose the multiroom tab in the app, I can select 'add product'. The NL/ML converter is mentioned there as a product type that can be added, but when I click on it I get an error message, saying that it can't find the product.
I never added it this way in the past (I'm not sure if that was an option or not), but I find it strange that the product type is mentioned, but it cannot find the converter.
Anyway: thanks again for any insights!
Just to say the B&O app has always been quite flakey with my ml/nl converter. I’m not a big user of the app, but interested to hear how you get on. Good luck ?
Never mind: if all else fails, unplug everything, plug it back in and hope for the best.
Hoping for the best works, everything is fine now. Nothing to see here, move along ;-).
Please report back with your progress. I'm on the fence about re-adding a BLC to my setup, but I worry about whether it will still work in a couple years.
Hi, I am operating some BLC and had a similar issue once with one of the units. I had to reset it and after that it was working fine again. Maybe this could be worth a try? Kind regards, RolfLocation: Germany
