NL/ML Converter with Beosystem 7000
I would like to control my Beosystem 7000 with my Beoremote Halo.
My current setup looks like this:
NL/ML Converter → MASTER LINK → BEOLINK 1611 → BEOMASTER 7000 (AUX INPUT)
The NL/ML Converter is configured as V Master.
The NL/ML Converter has SW 1.4.0.18322.
Under "Experience mapped to NL," the setup appears as shown (see Image 1).
Login to view image
In the Bang & Olufsen app, I have added the NL/ML Converter and given the Beoremote Halo access to control it. The problem is that no sources appear on the Halo or in the NL/ML Converter within the app.
Login to view image Login to view image Login to view image
Am I doing something wrong?
presumably is the sw version in this Beolink NL/ML converter the cause of this phenomenon.
the latest sw version = 1.4.3.19864
no auto software update of a BLC available anymore, so you have to go to a dealer to update!
Thank you for your comment.
Yes, I can read that in other forum. I will contact my dealer :)
I've now updated the NL/ML, and I can control my BeoSystem 7000 using the BeoRemote Halo. However, when I press RADIO, the system starts in mute on the BeoSystem 7000.
