MLGW undocumented commands
Hi @Frog Maybe the info in this thread helps: https://beoworld.org/forums/search/MLGW/   By the way, searching is quite easy. If you click on "Forums" in the main menu of Beoworld, you will see the search field.
Does anyone have the code to the unpublished MLGW feature? I couldn’t search this forum - maybe I’m missing something, but I couldn’t find a search box.
Thanks - good to know, but the undocumented command thread doesn’t appear in the search. someone wrote some code that could access extra functions and posted a thread. That’s what I’m looking for
OK, at least you now know how to search.
I remember that thread, but couldn't find it... You may find in on Github as I think he'd place the code there. p.
