I’m thinking about buying a Master Link Gateway, but it seems like in order to use it with BeoLab 3500 you need a firmware version 3.3 or higher, my BL3500 are firmware version 2.0 and I can’t find any PCB36 with FW 3.3, also I have 5 of them so it would be expensive.
Can someone confirm, that it won’t work with the lower FW versions before I buy a MLGW?
Best regards
Christian
