MCL2 AV no 5,5V
I have aquired a MCL2 AV for some testing purposes. first test of it with 15V power, tranciver, speakers in powerlink socket, and beocord 3500 in tape socket. No reaction to remote. No led light in the tranciver. tried to do some measurements, and there is no 5,5V after IC20 I got 11.6V before IC20 where the servicemanual says 10.6V i got 12V after IC21 and 6V after IC12 asit should be any clues what to look for?
Am I right in assuming that the MCL2 AV will start up and work stand alone without connection to a MCL master?
Yes thats the way cabling should look like in a man cave ? I dont have the original PSU so I am using a bench power supply with wires soldered to the PCB. It should be ok as I am getting the right voltage levels other places on the board except that 5.5V that is not showing up.
Have you checked the connection/wiring of the IR eye?  I think that is one of the 'users' of the 5.5V supply, hence could be shorting it out if wired incorrectly?
Hi again and thanks for the hint. the problem persists without the IR eye connected, so may not be that. Right now im suspecting an SMD transistor
Guy, is there a pin connection drawing on the PSU for your MCL2-AV if you have it handy? thsnks in advance
Here you go:  (I am getting better at finding things!)
Thank you very much. Then I can rule out errors regarding these specifications
Not sure if this helps - I think this is quite a late model without the passive speaker or RF connections.  The label says Type 2032.
