MasterLink USB adapter
Hi, I have this fancy circuit here that allows easy communication with any ML device out there. In the other thread I was thinking about a light version that would be more or less an USB-ML converter.
Sounds interesting ?
Great, thanks for confirming. Meanwhile I  created a block diagram of the solution in question. More or less copied over the audio block form the universal link adapter project. Just added a simple USB I2S bridge. While there are several other ways implementing it on the audio side -  those two chips (ADC & DAC) are working well with ML and only require minimal surrounding components. For ML master/slave selection I probably just add a manual switch on the board. I see no application where this needs to be changed programatically during runtime...
Fair enough. It seems like the numbers were against the ULA concept. The subset of people that have the need for such a device, would want to pay a fair price for it, and have the skills and motivation to write the supporting code would be pretty small. However, a similar argument can be made for something like the Beolab 90, yet it exists ;-). Glitch
I would LOVE this device!
