Master link Audio Master
what is the easiest way to add the signal in Masterlink to convince other devices that a ML Ausio master is attached?
I note that in the ML/NL converter you can get a box that will do that, but what does it do?
maybe it would be easy to make one? Any idea of what voltage and what wire on the ML connector is needed?
If I understand you correct it might be the 1611 Beolink converter you are looking for. Take a look in this rather long thread
link
it will give both a audio and a video source availeble on Masterlink.
Meaning you can from a Beovision with masterlink press any audiosource button and the 1611 Beolink converter will activate the correct input pins (1, 4 and 2 for audio) in its datalink connector.
Also see Matadors very informative drawing where it is used with a Beolab 3500 as a stand alone solution
I think what you are saying is that if I attach a 1611, then I won’t need an audio master? I’m not using datalink, just ML and NL.
I think that would be the case depending on your setup and goal. My knowledge of the ML/NL converter is limited, so my answer is for the ML part.
in the linked thread it was tested with both Beolab 2000 and 3500 as well as different Beovisions and a Beport without other components in the Masterlink chain.
That is what the ML-Powerbox does. This was introduced at a time where B&O did not make the 1611 anymore. MM
Thanks.
