Buying advice BLC NL/ML
I am considering buying a Beolink Converter NL/ML and need some advice before deciding if I will do it. Thanks in advance
  1. Do I need to ask if the BLC is updated to the newest software or is it still possible to update it online? I don't see any software downloads on the B&O support page.
  2. I seem to remember that I read in a thread that the ML power box can be substituted with a 1611 Beolink Converter if no audiomaster is present on the ML side of the BLC. Is that correct?
  3. What is the function of the AUX input on the BLC? Is it only for playing to the local powerlink connectors or can it be distributed to the ML and/or NL side of the BLC?
  4. Does the AUX input have audiosense for automatic playback when a source is playing?
  1. AFAIK, you can no longer download the software so I would ask about the version.  Unfortunately, my experience is that this is usually answered "I don't know".  I've been in the market on and off for a BLC for a while, and I have not bought anything because of this.
  2. Don't know
  3. Aux can be distributed to both ML and NL sides as well as local powerlinks.
  4. Yes.
Ok so software is an important issue. What is the latest software version for the BLC?
Hi Madskp,
look here, please, that thread will help you:
Hi Madskp, look here, please, that thread will help you: Kind regards, Rolf
Thanks a lot, great info, might have overlooked that thread while searching for it.
link
link Does the AUX input have audiosense for automatic playback when a source is playing?
All on my 3 BLC are on the same and latest software version which is:
Version : 1.4.3.19864
Date : Dec 11 2015
I would assume that all boxes for sale would be on the same version and if not, I would recon that it would download the latest and update the box. At least I'm not getting any errors when I ask the units to check for software update; just get that I have the latest version already.
To be honest I think you can assume that it has the latest firmware and if not, then just reach out to B&O Support to get help or check with a dealer if they can help you to perform update using their service tools.
link
My experience: I once bought a BLC, at that time indifferent of sw versions. It was cheap and I purchased without asking and it turned out to be on a lower sw version.
Now, this said unit was two updates behind. Customer service pointed at the online update and that it should work. And it did not update, neither automatically nor manually. Asking customer service, they told me, that in this case, only a dealer would be capable of updating the unit with his service tool. I asked my dealer who was not aware of this problem and if it would work. I gave it a try and he did it for a decent price.
First, it seemed to work well. At some point, it started to fail punctually, no longer reliably transmitting the data and music. In the end, I let it be checked by my dealer again and he had to exchange the complete inside electronics.
All of my other (3) BLC have the latest sw. If I try to update manually, I receive something like „it is on the latest sw version“. So from my experience and according to customer service (I guess 2 years ago), it seems that you can still update a unit online, if it is not on the latest sw. But it seems to me that it is likely not possible, if the actual version is too far behind the latest update. I also cannot exclude the possibility that my unit had been faulty right from the start and that this has been the reason that it did not update.
Personally, I would still go for a BLC to merge my ML and NL products. I have that „new“ BLC now stored, planning to connect my BC 9500 / BG 9500 to my network one day ?.
But info about sw version - my point of view - is important to minimize the risk of buying units with hidden faults or not behaving correctly. So, if the seller is not sure about the sw version and he wants to sell, than it should be possible to plug the unit into the mains, connect via LAN to the network and check the sw version. Takes about 2 minutes.
Alternatively, you could ask him, if he is willing to confirm that he will take the unit back, if the sw version is behind and can not be updated.
Kind regards,
Rolf
