- My audio master is a BS5 set to audio master mode
- My BLC is set to video master
- I have B&O Radio on my BS1 mapped to TV on the ML side
- I have all of the ML source turned on for the NL experience
BLC questions
I recently picked up a BLC and I'm having some challenges getting it setup. On the ML side, I have a BS5 and BL3500. On the NL side, I have various devices, but focusing on the BS1 Gen2 GVA for now.
I was missing something for the BS5 configuration. I had to set the audio option to 2 on the BS5 for it to respond to non-BS5 commands like TV. It was set to 1 by default, I assume, when I switched it to audio master. For most of its life, the BS5 worked with a BS9000 so I never had it set to audio master until recently (when my BS9000 died and has yet to be fixed).
Still not sure how to see the ML sources from the NL side of the world. I guess I will dig into the old forum...
Figured out the NL side as well. Need to add the BLC as a product to the B&O App.
Well, I had a nice conversation with myself here :D
Is there a more direct way to listen to ML sources in the NL world than playing the ML source on the BLC, then joining the NL device to the BLC?
On my NL network I have an A6, like so:
Login to view image
From the B&O app, while the A6 is selected, I can depress the three dots on the lower right hand side and I get the following options, plus CD, A.AUX, LINE IN, N.RADIO, Open Spotify App, and Standby.
Login to view image
The sources local to the A6, such as B&O Radio, are reliable. The sources remote to the A6, such as N.RADIO or N.MUSIC, are very unreliable when called up directly from the A6.
To make the system behave reliably, I activate sources that are local —such as CD on the wired Master Link, or Deezer on the A6— and then JOIN from or to the other environment.
Yeah, the BLC is a bit wonky, apparently.
Login to view image
Login to view image
Is there a more direct way to listen to ML sources in the NL world than playing the ML source on the BLC, then joining the NL device to the BLC?I'm not aware if the BS1 gen.2 has the capability, but did you set the primary Link to other product" in the BS1 configuration (set-up / beolink). And there after "Your content / Sources / Local list" selected also the sources of the BLC connected ML? If the BS1 doesn't have this option, you should consider another NL device.
On my NL network I have an A6, like so: Login to view image The sources remote to the A6, such as N.RADIO or N.MUSIC, are very unreliable when called up directly from the A6.How reliable is the old Airplay Express in this setup? I find all my BLC reliable, but all of them are wired LAN connected.
My experience has been that 3rd generation (the with-separate-power-cord type) is still going strong, both as a solid, never-reboot AirPlay2 (with the last firmware) endpoint and as a gateway of wired Ethernet to the "main" Wi-Fi router. The 1st generation (integrated-plug) has started to fail, sometimes seemingly having little Wi-Fi range, though it's usually the tough-to-repair power supply at fault. Hopefully @XavierItzmann will reply too.
Configuring "Link to other product” setting as Carolpa suggested did the trick. Thanks for the help everyone!
Also, I've been using an Airport Express 3rd gen for quite a few years in a manner similar to XavierItzmann's diagram above (providing a wireless ethernet connection for my BS5). It works fine. Similarly, I had an earlier version that went wonky.
