BeoLink NL/ML converters offline
This morning all three of my BeoLink NL/ML converters - each in a different room and with separate power and Ethernet connections - are offline. I can’t even open the webpage to reach them. They were working fine earlier this week. Has anyone else experienced the same?
Thank you, Carolpa. Restarting the router had no effect (still no webpage), but restarting the BL NL/ML boxes did the trick. As a person working in IT, simply rebooting a device SHOULD BE the method of last resort.  It means that one has no idea what went wrong, and you’re clutching at straws. As a realist, rebooting should be the first resort, because it so often GETS AROUND (does not resolve) the root cause issue. (Sigh) I looked at the logs: nothing.  Wiped clean on one, and nothing between 10Oct and today on the other.  And I know I used the latter one earlier this week. Thanks for taking the time to reply, Carolpa.  To me, your posts on BL NL/ML are the reference user guide for the device.  Enjoy the remainder of the weekend. Lawrence
