I'm at a loss how to configure the Beolink Converter NL/ML - A.Master shouldn't work as I already have one, but A.Slave doesn't allow me to select any sources on the NL (or ML) network with the Beolink Passive/
I'm trying to connect a BLC to a NK/ML mixed network. to do this, I've connected a Beolink Passive (with speakers attached) to a BeoLink Converter NL/ML via Masterlink , the Beolink Converter NL/ML is in turn is connected to the NL network. I already have an audio master in the ML network. Connecting the Beolink passive to the ML network works fine - but as I want to move this to a different location, I have the converter in-between
Here are my answers:
Question 1: which of the following is your setup
a. BL Passive ML connected to BLC – NL devices – another BLC ML connected to your A.Master, or
b. A.Master ML connected to BL Passive ML connected to BLC – NL devices?
>>config A is the setup
Question 2: which NL devices are connected?
>> I have a Beosystem 4, the other NL/ML converter, a Beovision 11
Question 3: you want to move the BLC/BL Passive, does this room have a NL device?
>> no, it’s a bathroom, so no other device is in the room.
Yes, as above. There are more ML devices connected (too many to list!) no speakers are connected to either BLC ML/NLs. I've used the first BLC-ML/NL as a bridge between the two networks - and its working fine/
Yes, as above. There are more ML devices connected (too many to list!) no speakers are connected to either BLC ML/NLs. I’ve used the first BLC-ML/NL as a bridge between the two networks – and its working fine/.I would make the next setup: a. Disconnect the ML between the BLC and the BL Passive b. Connect both with PL c. Set this BLC as V.Master d. Set for this BLC Networklink", "Connect to (primary)": the other BLC e. Be sure all the sources of the other BLC are set in "Experiece mapped to NL" f. advice: add an IR-eye to the BLC (with the BL passive connected; IR-eye with the "JOIN" button) to listen to your A.Master on the BLC with the BL Passive. 1. open B&o app 2. tap the BLC (with the BL Passive) 3. tap the black bar below with the name of this BLC 4. tap the three dots 5. select the/ a source of the A.Master To test this setup, I have connected BL8000 to a BLC. Another BLC is ML connected to a BS3000. The sources CD, Radio and Aux are made available to NL. The BS3000 BLC is set "Connect to (primary)". As described I started the BS3000 CD to the other BLC. addition: to be able to set the volumes of the BLC, go to "Settings", "Beolink" and set the "BLC Network Link volume" in the App
Thanks - I’ll give this a go - basically using the BLP and passive speaker as an active speaker directly connected to the BLC.
really though; I can’t understand why the BLP connected via ML isn’t working.
Well I tried the above setup - initially with a Beolab 8000 connected to the powerlink connector of the BLC and weirdly, the only source that worked came from the Beosystem 4 - but I di get NETRADIO coming through the speaker.
On disconnecting the powerlink and connecting it to the BLP with Beovox 1s attached - the BLP didn't even power on. I'm at a loss to understand why as surely the BLP should activate if it senses a signal on the PL.
Probably not…. I’ll try to find some and try again.
