I have a Beosound 4, Beosound 5 (set to Slave mode) and a Beosystem 3, all connected via ML. my speakers are connected to the Beosystem 3.
I have added the BL Converter too, which has an IR Eye connected. I don't seem to be able to get anything from the IR mapping options however.
Specifically (for reasons too long-winded to explain here!), I was hoping that I could get the Phono or N.Radio remote command to select the A.Aux input on my Beosound 4.
I've tried setting that in the IR Mapping tab so N.Radio is goes to A.Aux, but it does not work. If I have the Beosystem 3 set in Opt.0, nothing happens at all. If I have the Beosystem 3 set in Opt.2, I get Phono/N.Radio when I select Phono/N.Radio as a source button, rather than A.Aux.
