Beolink Converter
Hi, Is it possible to use the Beolink converter with an IR eye/transceiver ?  the plug is provided. If yes, i need the the Din Plug wiring   Thanks Theo
  Is this what you are looking for? MM
Hi,   Thanks, but i need it for a Din plug. I have the cable but the wires are black, red, yellow, white and shield, so i don't know how to solder my din plug   Theo
This is from  Beolink handbook 1.9
Which ‘beolink converter’ do you mean? If you mean the ML/MCL Converter, the posted pic from sverreh is the right one. In that case your ‘beolink converter’ - with the ir eye - is what usually is called a ‘Beolink Passive’. My post is for the ML/NL Converter. MM
