Beolink 7000 - belt
I have started taking a Beolink 7000 apart to replace capacitors as it has the well known no contact issue. When I opened it up I noticed that there is a belt from the motor to the lifting mechanism which seems a little loose although still good enough to lift remote. But since I am already disassembling the remote I might as well replace the belt. However Danish Soundparts do not have this belt, so I am wondering if anyone else has the correct size for this belt? Thanks I advance
Hi, I used 1 mm X 33mm ID round belts (o-rings) on mine and they work fine. Good luck, Bill
Thank you very much πŸ˜€ It’s always hard to judge how much these old belts have stretched over the years Now to find a place to source them
