I use a Beolink 5000 in one way mode to control things in my office.
Unfortunatly the remote seems to regularly return to two way mode making it complicated to use.
At first I thought it was a problem with battery contact: loose batteries cut power tus reverting it to initial state (two way).
I secured battery contacts si I think I can rule out this cause.
Do any of you experience this or have any idea?
Thanks.
