2 x BeoLink Passive - One Eye?
Hi all! Does anyone know if it's possible to have two BeoLink passives linked to the same eye, such that they operate simultaneously? Thanks!
Hello I would not recommend doing that. Another possibility could be to get a Beolink Active connected to the IR eye, and the use the two passives as amplifiers connected to powerlink on the Beolink Active. For this to work you will have to use fully wired mk2 Powerlink cables. This also includes the Y cable adapter you may need if you get the Beolink active with only one Powerlink connector. Hope this can be used as a solution
