Hum and buzz on BL3s to Theatre
Hi all, This is an issue I have intermittently dealt with on my Beolab 3s (both) connected to the Theatre. It’s actually becoming a pain just when I think I’ve got it solved, I come home and there the buzz is again. Most audible when I change volume but pretty constant. The buzzing is quite high frequency sound. Both BL3s are connected via Powerlink mk2 fully wired and connect via a splitter into PL1 port on Theatre. It is pretty hard to separate all the cables back there but I believe they are. Are there any tips for avoiding this issue? thx
I am no expert, but I read in the BL3 manual that hey specifically advice tyo use Mk3 cables as others might cause noise. I just noticed you mentioned you use Mk2.
Thanks, I recall that in the manual but I always thought that MK2 was compatible with everything and being the thicker type was less susceptible to noise.
I have the exact same issue - drives me crazy. I don't know if my pl cables are mk2 or mk3, but they are pretty thick and have the litte triangle... I tried to connect all speakers to the same power outlet, to rule out any ground loop, but it didn't help.
I dont think it is the cables - or rather it is (silly) I had the same issue taking a regular CAT7 (flat cable), connecting my Beolab3s (with RJ45 to PL connector) and the issue was bad. I could clearly hear an impulse when pressing vol +/-. I threw out all my PL cables and RJ45's and replaced the lot with Sound Heavenly cables. It worked but there is still a noise. Im not sure of other peoples setups, but I think this has a good deal to do with the number of PLs connected (3 pairs of BL3s) and the way Theatre controls the signals. Its workable, almost imperceivable unless your ear is against the driver but it is there. To summarise,
  1. Have good PL cables to improve cable hygiene
  2. Theatre may have a PL distribution issue.
Thanks, I recall that in the manual but I always thought that MK2 was compatible with everything and being the thicker type was less susceptible to noise. You would think so, but alas, not: Either the "spare" wires in the Mk.2 cables are picking up the noise, or else the Mk.3 cable is adding a ground. (Not specific to BL3; e.g. BV10->BL18 requires Mk.3 (4-wire) because Mk.2 (8-wire) makes that "data" chirp on volume up/dn.)
Maybe Steve have some inputs to whether or not it could be a cable issue?! :)
Hi, This issue shouldn't occur normally, but several factors can bring it on. Lack of grounding to the digital amps in ICE Power speakers can cause a low frequency mains hum or buzz sound, but this was described as a high frequency buzz in the original post, which sounds like something different... One option would be to connect just one speaker at a time to see if the noise is always there (does it come from the Theatre speakers as well?) and if all speakers are connected. There may be an equipment fault in there somewhere... Kind regards, Steve.
I built in a Powerlink cable system into the walls of my living room recently with home made Powerlink outlet sockets. I have a Beosystem 3 and Beosound 9000 and my 4 Beolab 3's worked perfectly before the installation (connected directly to the BS3). When all set up there was a hum/buzz. I couldn't replace the inbuilt wiring but used various cables to try to get rid of it. Eventually I bought my Beolab 12-3's from my sunroom into the living room, and tried just the one. No hum. Plugged the Beolab 3's back in, connected one and the hum stopped, unplugged it and it came back. So I have swapped 2 Beolab 3's to the sun room an put the 2 Beolab 12-3's in the living g room. I was thinking of getting a subwoofer as the 4 Beolab 3's didn't really fill the room with sound. The new setup means I don't think I need one as the bass is now more than adequate. There must be something in the speakers that sort the hum out. Just to add to your thoughts really. Stoobie
Exeter, Devon, UK
