Help with beolab 4000
Hi i am experiencing random sound cut off on one of my Beolabs 4000. The  sound disappears, can come back, just randomly comes and goes.
I changed the rca cable, opened the unit ( foam is fine it is the new one),checked for any loose cable, cleaned contacts with alcohol, sprayed the power switch with contact cleaner, nothing helps.
Any ideas ?
Chris
I would suggest swapping it from right to left just to check it is not the source - I guess you have done this already - in which case I can only imagine there is a fault in the amplifier - will need service - from experience, Multicare know what they are doing. About to take one of my Pentas in which has done something similar!
Ok thanks for your input and quick reply.
regards
chris
