Faulty Beolab 3500
Hi all, I reveived a beolab 3500 from a new owner of an old house with B&O material. But the beolab 3500 doesn't power on. Someone knows what i could verify  first ?   Thanks Theo from Strasbourg
Is there a red LED with lights on? If it is the later version of the BL3500 (MK2) it will not react to source commands if it is not connected to an audiomaster. To check for signs of life you could try to press Menu, 0, 0, GO on your remote (is it a BEO4 remote you have?) This should give som basic information in the display like sw version
Hi,   No red light on. And it's the mk1 version. i have a beo4 and a Bl1000. Thanks Theo
