- STL-file
- A 3D-printer and print 4 stl-files (I printed it with ABS medium)
- Wood 4 x 18 x 330 mm for every speaker 22
- Some double-sided tape for the ones on the side.
DIY Beolab 2500 Wood frets (STLs included)
This is my version 3 of the STL-file to print on a 3D-printer so you can make your own wooden frets on your Beolab 2500.
Print it out and drill holes in it so you can use the original screws to put it on your Beolabs 2500 after removing the fronts. I have tryed to make it to make it reversible.
You will need 2 printed STL for one speaker and 4 x 18 x 330 mm wooden frets.
So you need:
Hello Jabaar,
I can't see the file to download the STL-File.
Where can i find it?
Hallo Jabaar,
I am not able to see any attachments. Would you mind sharing the files, please?
Hallo Jabaar,
Ik kan de bestanden helaas niet zien. Kan je ze misschien naar mij sturen?
alvast bedankt!
mvg,
Devon
Hi friend where is the 3d file download please?
