BL3 on table stands pls help
Hi Beofans, would somebody with BL3's on table stands be so kind and tell me the total height? I have quite a limited space under cabinet and would like to be sure that my BL3's will fit after I buy  table stands, thanks. Oh and how thick is the base plate? Is it more then 6 mm?
Hi libor, welcome! I do not have these speakers but found a pdf catalogue that says they are 32cm high: I trust they will need a bit of space around them to work correctly, that will for sure be written in the manual. At the B&O website you can download an '.obj' file of the BeoLab 3 that might give you the exact height of the base (using a CAD system). Good luck, would be nice to see a photograph of the result in the 'Flash your B&O' thread! Regards, Johan
The .obj file shows like this in my standard mac preview app (I cannot measure it there, sorry).
Hi libor, I can confirm a total height of 32 cm as Johan has displayed. I have the BL 3 on table stands in our bookshelf. In my case, I was able to build the bookshelf around the speakers :-). The round base plate is 6 mm thick and it stands on rubber feet which take appr. 0,5 - 1 mm in height (I cannot measure more accurate, sorry). I hope it helps. Kind regards, Rolf
Hi libor. If you have limited space/height there, why not go for the rubber stands instead? Would also make it easier to point the speakers a bit up or down depending on what you’d need. Please do not move these speakers too far back from the edge of the shelf/cabinet - the Acoustic Lenses need space for spreading the sound. MM
