Beosound Core with Beolab 5 - streaming capability
Please note the ‘workaround’ that Steve mentions here: https://archivedforum2.beoworld.org/forums/p/25222/201651.aspx#201651 MM
Dear all, Would anyone of you already experienced connecting a BS Core direclty to a BL 5? I was told sound quality could be reduced compared (distortion if I understood right) to standard B&O CD player, and that it would be better to plug BS Core the BS CD player Aux. Did you already experienced such issues? Would you have in mind an alternative to BS Core that could stream music directly to the BL 5 with capability to control volume, and turn On/Off the speakers? By the way, BS Core are on sales for a pretty long time now, and even currently out of stock on the B&O website, did you hear about a new hub solution planned in a near future? Thank you for your feedback, Ben
Setup : BL 4000/2/3/5 mk1/20 Beoplay H6/H95 BS 4/ Transmitter 1
This is the official B&O suggestion: As for ‘new hub’, there is nothing official yet. However, rumour says there will be a Mozart platform based version of the BS Core at some point. MM
I would imagine that a Core plugged in to a BL5 (TOS/Coax + PL) would not have any problems. How it sounds....well that is for you to decide by testing at home or with your Dealer. The trick with the BL5 is to always use a digital signal in for music over Powerlink. I have seen the core as out-of-stock and Im trying to find the source but believe the Core may be getting a WISA/Mozart update soon with a new chipset. (??)
The probably coming version was discussed in the Beotalk 239 on sunday: https://youtu.be/zbB08TnZLzE Scroll to 1.42 MM
Thank you all for your knowledgeable feedback. This is great to see interest on that topic. An upgrade to Wisa would be great. As you guys mentioned, the best is to test. I will ask my local seller if he would have one I could try at home. I was not familiar with Mozart and I found a good article if any would like to read : https://www.flatpanelshd.com/news.php?subaction=showfull&id=1665035559
@Ben88F In order to use WiSA with a speaker, that is not WiSA compatiple per default, you would have to use a Beolab Receiver 1. These however, do not work with the BL5’s. MM
Good to know the receivers are not compatible with BL5, thanks for the note.
